Link G4 1g DBW conversion help
obx tsi
199
Dec 1, 2005
Manteo, North Carolina
I'm looking for help from someone who has done the DBW conversion using the evospecperformance parts and had there g4+ ECU modified by Link.
I have the pedal and wiring harness installed.
Received ECU today and I am unsure of what wires I need to hook to ECU. Evospec wiring has the expansion connector on there end. My ECU also has extra wires now labeled an volt 7, 11 aux 9, 10 and ign 5, 6. I did ask them to set ECU up for coil on plug as a future thing.
I'm unsure of what the extra wires are for.
Should be aux 9 and 10 on g4+
It should tell you the output wiring in the pclink software when setting it up.
Those extra wires are your dbw wires, and they should be labeled.
