17psi DSM T25/T28 Actuator
WSU99GSX
525
Mar 16, 2004
Peoria, Arizona
I already searched and found little data that answered my question. Here it is, on a stock T25 will one of these show any improvement? From what I read you can adjust them and allow the T25 to hold boost alittle longer then the typical fall off point of about 5500 RPM. I guess I am wondering if I would see $100 worth of improvement....and yes I know the T25 is small, and flows bad, yadda yadda.
Putting a 17psi actuator on your turbo is the equivalent of setting your mbc to 17psi. It will have no effect on the turbo's ability to hold boost at the top end.
