11-12 psi max boost
super97gst
376
10
Nov 18, 2004
Clinton, Kentucky
ok guys, here's my problem. a couple of weeks ago i got in my gst and it just wouldnt boost over 12 psi max. well maybe 12.3 or 4, anyways, it had been working just fine until this happened. i have done several boost leak tests and cant find anything. ive also done exhaust leak checks and cant find anything.
as far as the turbo goes i am still running the t25. stock wastegate actuator, but i have a greddy profec ebc. i installed it a couple years ago so i know it is installed correctly. it doesnt matter how high i turn the ebc up, it still only pulls to 12 psi. the ebc will turn the boost down though. i replaced my stock turbo with another t25 about 6 months ago, but maybe its going down i dont know.
i did search on this for anyone who wants to say something about it, but i couldnt find exactly my problem. all of my mods are listed in my profile if they are needed. thanks in advance for any help offered.
Check for shaft play. Sometimes when the bearings/seals are going out, the friction keeps the compressor wheel from spinning as fast as it needs to.
How is the boost building? When are you getting 12.whatever psi? Maybe cracked turbine housing? Or are you sure your boost controller is working at all? Maybe try a mbc for a few days. EBC's still use a solenoid and they dont last forever.
