10w-30, 5w-30 or 10w-40
2DaTrakNow
265
7
Dec 20, 2005
hillsdale, Michigan
Which weight of oil should be used in our cars? I use either Mobil 1 synthetic, or Castrol Syntec, but every time i go to buy my oil i never remember what should be used. 10w-40 is what ive been using. Also, i know this might sound stupid, but exactly do the numbers stand for? I realize that 5w-30 is "thinner" than 10w-30, but how do the oil companies come up with the 5's, 10's, 30's and 40's?
I'm not in the oil business and not all that bright in general so I can't tell you the specific meanings of 5, 10, 15 and 20 (other than what you already mentioned), but I can tell you that 10W-30 is fine for your motor. For higher compression setups that make more heat, thicker oils work better. I run 20W-50 conventional and will switch to 15W-50 synthetic when break in is finished.
Hope that helps,
Andy
The first number is the flow rating when the oil is cold and the second number is the flow rating when the oil is hot.
I like 15W-40 because I live in NC and we dont get that cold of weather, plus the higher weight will protect parts better. You'll scarifice a little gas milage tho.
so the higher numbers flow less, and are "thicker". So if i live in a warm place, i would pay more attention to the higher number. Then once it starts getting cold out, i should look for a lower first number? Also, since i ran 10w-40 in it last time, i could probably go ahead and run it again right?
The numbers usually refer to weight. 40 weight 50 weight. Now in colder weather you want a lower first number. If you have a high first number it will take sooo long to warm up and will stick to the bottom of your oil pan till kingdom come. Now a higher first number like 15-30 or 10-30 is usually what normal weather people usually would use for summer. hope this helped
So hang on...i think i understand, but i am going to double check, so please be patient with me! Some of these i know, and some i am trying to find out. Will somebody tell me what is true and what is false.
-The numbers refere to the weight of the oil.
-The first number is the weight of the oil when it is cold.
-The second number is the weight of the oil when it is hot.
-The higher the number, the thicker the oil is and the slower it will flow.
-For example, 10w-40 has a 10 weight when it is cold, and a 40 weight when it is warm.
-5w-40 is thinner than 10w-40 when it is cold.
-10w-40 is thinner than 10w-50 when it is warm.
First off viscosity is the internal friction or resistance to flow of a liquid. An oil of low viscosity will flow easily than an oil of high viscosity. Viscosity is measured by how much of a liquid can flow through a given orifice at a given rate compared to water.
There are single-viscosity and multi-viscosity oils. Single-viscosity (ex. SAE 30) oils are used in areas where the temperature is consistent. Multi-viscosity oils (ex. 10W-30) are used in areas where there are seasonal changes or extreme temperature differences between morning and evening. A low numerical viscosity is needed in cold weather, or the engine will have difficulty turning over due to the resistance of the thick oil. A high numerical viscosity oil is needed in hot weather, or the oil will thin out and will not provide enough protection for the engine components.
In oil grades, a "W" stands for winter grade and means that the viscosity test was preformed at temperature of zero degrees Fahrenheit. The "W" in a 10W-30 oil, for example, means that a viscosity of 10 was obtained when the oil was tested at zero degrees Fahrenheit. The absence of the "W" after the 30 designates that a viscosity of 40 was obtained at 210 degrees Fahrenheit.
EDIT: MadTripper beat me to it buy a link, and I spent all that time typing that. Oh well :)
So, everyone pretty much said the same thing. IMO, here the most important part of the oil rating is the top end. Since you live in michigan, Id use 0W-40 or 5W-40 at the very most.
i really wont drive my car in the winter though. Some mornings through-out the summer it gets somewhat chilly, but not "freezing" or anything like that. But i will consider at least he 5W-40 just incase!
My dad lives in Michigan. He has a 7 liter F250 Desiel that is pretty unforgiving when it comes to lubrication. He is forced to use a block heater, which utilizes two power plugs.
I live in Illinois, and for example, I as well as many others use 5w 30 in the winter and 10w 30 in the summer.
well i went to autozone to pick up my oil, and ive already tried mobil one, and castrol syntec synthetic oils, and i wanted to try to quaker state Q stuff. Well they only had 10w-40 in the "high RPM" oil. I just wanted the "advanced performance" kind, and they only had 5w-30. It seems to be really thin (looking through the clear bottle slightly shaking it), but would anybody recomend this oil? I have never really heard too much about it on this website, just commercials! So the weight of oil i got should be good(or would 5w-30 be too thin?), and what about the brand and type?
