Street Build Taiga my first car
99 Eclipse GS, trying to build it up and make it look clean. No I don’t have a 4G63T because 420A was cheaper.. lol
Well the motor for the GS blew… LOL so now we’re motor swapping it with another 420a. This one is low mileage it’s around 117k miles? Hopefully this one will last another 100k miles. Old one gave out @227k miles. Bad compression on the old one (red valve cover)
Low compression and piston slap are the 2 main causes of failure for old and worn 420A. You're right on par with the mileage too. Though I've seen them die at 300k with good maintenance and mostly highway miles.
If you were to thoroughly and properly build an engine, it would last for a long time and take tons of abuse. Hopefully this gets you back on the road for a while though.
And hopefully there aren't any hidden gremlins that you weren't informed of. I recently bought and installed a 48k mile engine on a Honda. Was supposed to drop in and go with a 5 year 50k warranty. First drive I found that the VVT solenoid was not functional and the valve cover gasket was leaking. Luckily they reimbursed me for those parts.
Yeah that sounds right. I have seen around 300,000 as well. Yeah, hopefully I wasn’t sold the bad engine because that’ll be shitty. Also with the GST automatic transmission that I’m already having rebuild. My pockets are drained. All that’s left is sensors to be reconnected and axles to be put back in. I’m having a dilemma though because one of the axles is kind of thread crossed I’m not sure how that happened but I have to figure that out re-thread them with the tool or kind of file it or worse comes to worse get a new axle
The swap ended up going wrong. We got scammed buying this 420a motor. We were told it was low mileage and running but turns out the motor was blown. Held 90PSI compression.. after opening it up and inspecting the motor everything seems like the motor was 200k+ miles. It’s been a minute and I haven’t been active on her, so I will start to update more progress on this.
I decided to actually K-swap this chassis. I’m not throwing money anymore into these damn 420a. When they’re built it’s a cool motor but for me it ain’t it.
Ending up taking out everything that I’m not going to be needed. Cleaned and tried my best to degrease the entire engine. This is how she sits for now meanwhile I search for a K24, CRV transmission parts, subframes, axles, wiring harness, and lots of research to do. This is a project for sure , not a weekend project for me. Though it can be with the right amount of money on hand. Realistically I think the time frame for me will be about a year. That’s my goal. I’m doing most of the work my self to save as much as I can on labor costs.
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
