NATFAB 1G FORD 8.8 DIFF REAR SUBFRAME
The Ford 8.8" is a solid unit. Far better than the 7.5" unit in terms of building boost and towing capacity. Hopefully someone can benefit from this.
My 4 cylinder Ranger was swapped from a 7.5" to an 8.8" at some point. I wasn't aware at first, but I can definitely tell a difference in terms of gear ratio, especially when pulling/towing or choosing when to shift into overdrive. I know it will last a bit longer too.
That powdercoating looks great as well.
  • For sale 4G63 Antilag coil on plug, m&w ignition box, wilson Billet 90mm throttle body,
    I’m upgrading to fuel tech so I won’t have used for these parts I’m in the middle of a build and...
    • aguiga
  • Wanted 1G Fuel pressure / 2G boost solenoid
    Looking for a working 1G fuel pressure solenoid. Same part was used as a boost control solenoid...
    • Drewpy Dawg
  • Wanted Looking for T25 replacement
    2G, preferably a t28 or t25
    • Mando Vee
  • For sale 2g 2G Manual Shifter Cables
    2G Manual Shifter Cables $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 1G DSM COMPLETE A/C UNIT
    Came off a bone stock 1G, won’t be using. Good for anyone that’s looking to go back to a/c or...
    • The_Partout_Spot
