Wanted 4G63 ISO built short block
Looking for either a 7 bolt split thrust or 6 bolt
Yup he is right. Other ways to go about it. Mine were knocking (balance shafts) deleted them problem solved. Did it in car too but very difficult labor wise
If they're saying balance shaft bearing holes are bad then Just delete the shafts. You will still need to plug the front shaft holes but a bearing is not required to do thst. There are other ways.
Gabriel Pena
Gabriel Pena
That’s what I was thinking, at the end of the day I just need to close off the oil squirters with a tap and bolt correct?
pauleyman
pauleyman
No. Oil squirters aren't the problem. I assume machine shop told you balance shafts cant be fixed?
