1995 Eagle Talon TSi Vehicle Profile & Build Thread
Pine green, FWD, TSi. Not much to say really.
DD that's fun on track days
Ownership Status
Currently Own
Eagle Talon TSi
Turbo Type
16g
Drivetrain
FWD
Automatic
Build Type
  1. Street
E3 16g turdo, Oil cooler and filter relocation kit, DW200 FP and rewire 14v/17.5v with pump booster, 2.5in downpipe to sadly the stock cat and 3in catback , vac/boost gauge, 11x12x3 FMIC, 3rd gen focus ST throttle body and pedal, replaced hydraulic with electric power steering, battery relocation/replaced with super capacitor bank and small LiPo motorcycle battery with isolator relay (5lb total I think),
Mods-Engine
BC1100 springs, a slightly longer duration cam regrind (forget the numbers but its extremely tame), BS delete, ARP head studs,
Mods-EMS & Logging
EMU Black
Mods-Drivetrain
Auto trans shift kit with, 5 disc front clutch, bigger trans cooler. ForcedFour Shift Box DSM-Plus2, pressure solenoid controller.
cheap adjustable coil overs that finally need replacing, rear camber kit, AWD front calipers, 3rd gen brake booster and master cylinder, 17in wheels with 235 tires
Parts Wishlist
Injectors 950cc, adjustable cam gears, aftermarket steering wheel with ample spacing, TS Dash pro setup, Low voltage hybrid rear diff/battery/management.
Background
I wrote this many years ago in maybe 2016? I used () for edits on how its going now in 2026. I was in the market for a daily when I happened upon this car destined for the scrap yard. It was rough: misfires, stuck injector, oil leaks, bad mounts, bad front and rear suspension and breaks, cracked and warped valve cover, bad 02, sloppy turdo, rusted almost everything... Now it runs great (This was a lie I convinced myself as to not feel bad about what I had gotten myself into). Its a (SEMI) reliable car that I daily and use for deliveries when its not raining. A few (too many) mods left to do. Possibly tidy up a few mods that are already done so it looks perty (forget how it looks, at this point I just want it to run and not fall apart). Almost time to crank the boost (wishful thinking but maybe some day)
  • Like
Reactions: BLACK'98DSM
