1997 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
Street Build
1997 Eclipse Spyder GS-T M/T
Money Pit (Rabbit Hole)
Ownership Status
Currently Own
Turbo Type
16g
Drivetrain
FWD
Build Type
  1. Street
Forced Performance 68HTA Turbo (6851s)
CXRacing Front Mount Intercooler Kit
Injector Dynamics ID1050x Fuel Injectors
FP Cast Race Exhaust Manifold
Megan Racing 3” Turbo-Back Exhaust
TiAL 50mm Blow Off Valve & Hardware
CXRacing 3” Downpipe (2G GS-T FWD)
Miscellaneous Turbo Hardware (Summit & Extreme)
Slim Radiator Fans & STM Engine Tools
XS Power AGM Lightweight Battery (D925)
Extreme PSI 16G/68HTA Install Kit V2
STM 3” Aluminum Speed Density Intake Pipe
Summit / STM / Evil Energy Fittings & Adapters
FuelLab 81811 Inline Fuel Filter (6AN, 40-Micron)
Walbro 525 Fuel Pump w/ Install Kit (F90000285)
Fuelab Adjustable Fuel Pressure Regulator (#51502-1)
Megan Racing Aluminum Radiator
Mishimoto Baffled 2-Port Catch Can
Walbro 255LPH Fuel Pump & Install Kit (Replaced)
STM E85 Fuel Feed Line Kit
Silicone Radiator Hose Kit (Black)
STM Fuel Pump Rewire Kit
TRQ 2-Piece Ignition Coil Set
OEM Spark Plug Cover
NGK-8100 Spark Plug Wires
Russell Performance Push-On EFI Fittings
NGK BPR7ES Spark Plugs
Mods-Engine
Wiseco Forged Pistons (Provided by KSR)
STM Gates Timing Belt Kit w/ Water Pump
Brian Crower Cams #BC0104 (Provided by KSR)
Eagle H-Beam Rods w/ ARP2000 Bolts (KSR)
OEM Valve Cover Replacement
BC Springs & Titanium Retainers #BC0100 (KSR)
Kelford Balance Shaft Delete Kit
ARP Head Studs (4G63 7-Bolt)
King Main Bearings (Provided by KSR)
Cometic 86mm .040” Head Gasket
Rod Bearings (Provided by KSR)
OEM Thermostat Kit
OEM Front Main Crankshaft Seal
OEM Valve Cover Collar Bolts
Mods-EMS & Logging
ECMLink v3 Package w/ Eprom ECU
AEM X-Series Wideband UEGO Air/Fuel Gauge
Speed Density Bundle Kit
ECMLink v3 USB Datalogging Cable
Motion Works Electronic Boost Control Solenoid
AC Delco GM Genuine Flex Fuel Sensor
ECMLink Speed Density Cable (#27533)
Auto Meter Dual Gauge A-Pillar Pod
GlowShift 30 PSI Boost/Vacuum Gauge Kit
Russell Fuel Pressure Gauge
GM Flex Fuel Sensor Pigtail Harness
OBD II Port Replacement
Mods-Drivetrain
TMZ Quaife QDH7B LSD (FWD F5M33 Transmission)
AdlerSpeed Twin Disc Clutch Kit + Flywheel
Fidanza Short Shifter & Bushings Kit
Prothane Black Polyurethane Motor Mount Inserts
Extreme PSI 7-Bolt Flywheel Bolt Kit
Nitto NT05 Performance Tires (235/40/17)
KYB AGX Adjustable Struts (Set of 4)
Break Performance Cross-Drilled & Slotted Brake Kit
Tein S-Tech Lowering Springs
Russell Stainless Steel Braided Brake Lines
Prothane Suspension Bushings Set
Chidsey's Auto Wheel Alignment
KYB Front & Rear Strut Boots (SB103)
KYB Strut Mount Plates (#SM5091)
KYB Coil Spring Insulators (#SM5433)
Parts Wishlist
None—all items are acquired parts accounted for in the primary build categories
Background
Luxury Window Film Tinting
A/C Compressor Unit
Touch Up Direct Minden Silver Pearl (A52) Paint
Extreme PSI Fuse Kit
ECMLink Decal Stickers
Dyno HP
453 whp
417 lb/ft
Dyno Type
Dyno Dynamics
