Daily street build 95 Talon (newbie)
- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 14b
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- 1995 Eagle Talon TSI AWD A/T
101,000 km on motor
176,000 on trans
278,000 on body
- New gaskets & head gaskets
- new aftermarket IPT end clutch kit
- New BR7ES spark plugs
- New 15w40 oil and Wix filter
- New trans pan gasket and IPT filter
- New trans fluid (power flushed)
- new Vibrant intake filter
- New thermostat rated to run
cooler then the OEM rating
- New Billet Adjustable Actuator
Set with 1.0 Bar springs (15psi)
- brand new 15mm hubcentric bolt on spacers to fit offset rims.
- Rare Hoshino Impuls RS3 rims
- timing belt
- Arp head studs
- Manual boost controller
- Greddy blow off valve
- 2.5" to straight back 3" exhuast
- 3" MAF conversion & MAF tuner
- front mount intercooler
- aftermarket aluminum half rad
(Fan direct wired to toggle)
- fuel pump wired to switch with 30A fuse
- interior blue LED lights (toggle switch)
- wired for subs
- double din cd/dvd player
-14B turbo (solid) @ 15psi
- Mods-Engine
- N/A
- Mods-EMS & Logging
- N/A
- Mods-Drivetrain
- - IPT end clutch kit
- Mods-Handling
- N/A
- Parts Wishlist
- Mods needed for car
- Ecmlink V3
- shift box (forced four)
- 750cc+ injectors & fuel rail
- 255 walbro fuel pump
- front & rear suspension
- exhuast & Intake manifold
- upgraded diff/tcase
- Evo 3 conversion trans kit
- probably more that I'm missing
