1. Join the Community!
Daily street build 95 Talon (newbie)
Year:
1995
Model/Trim:
Eagle Talon TSi AWD
  • Ownership Status:
    I own it
    Turbo Type:
    14b
    Drivetrain:
    AWD
    Transmission Type:
    Automatic
    Build Type:
    • Street
    Mods-Bolt-on:
    1995 Eagle Talon TSI AWD A/T
    101,000 km on motor
    176,000 on trans
    278,000 on body
    - New gaskets & head gaskets
    - new aftermarket IPT end clutch kit
    - New BR7ES spark plugs
    - New 15w40 oil and Wix filter
    - New trans pan gasket and IPT filter
    - New trans fluid (power flushed)
    - new Vibrant intake filter
    - New thermostat rated to run
    cooler then the OEM rating
    - New Billet Adjustable Actuator
    Set with 1.0 Bar springs (15psi)
    - brand new 15mm hubcentric bolt on spacers to fit offset rims.
    - Rare Hoshino Impuls RS3 rims
    - timing belt
    - Arp head studs
    - Manual boost controller
    - Greddy blow off valve
    - 2.5" to straight back 3" exhuast
    - 3" MAF conversion & MAF tuner
    - front mount intercooler
    - aftermarket aluminum half rad
    (Fan direct wired to toggle)
    - fuel pump wired to switch with 30A fuse
    - interior blue LED lights (toggle switch)
    - wired for subs
    - double din cd/dvd player
    -14B turbo (solid) @ 15psi
    Mods-Engine:
    N/A
    Mods-EMS & Logging:
    N/A
    Mods-Drivetrain:
    - IPT end clutch kit
    Mods-Handling:
    N/A
    Parts Wishlist:
    Mods needed for car
    - Ecmlink V3
    - shift box (forced four)
    - 750cc+ injectors & fuel rail
    - 255 walbro fuel pump
    - front & rear suspension
    - exhuast & Intake manifold
    - upgraded diff/tcase
    - Evo 3 conversion trans kit
    - probably more that I'm missing
Share this Item
TNi likes this.
Comments
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
