95 Eclipse GSX
- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- -T3 Exhaust Manifold
-HX35 7 Blade Turbocharger
-Tial 44mm Wastegate/Dump Tube
-VRSF Front Mount Intercooler
-Tial 50mm Blow Off Valve
-Hallman Manual Boost Controller
-3in Thermal Exhaust
-Vibrant Dual Tip Muffler
-Fuelab Adjustable Fuel Pressure Regulator
-PTE 1200cc Fuel Injectors
-DW300 Fuel Pump
- Mods-Engine
- -Stock 2.0L 4G63 (15psi)
-8.5:1 CR
-Evo 9 Oil Filter Housing
-STM Oil Cooler
-GSC 274/274 Camshafts
-BC Valve Springs
-Kiggly HLA Regulator
-ARP Head Studs
-1G 60mm Throttle Body
-IAC/FIAV Block Off Plate
-EGR Block Off Plate
-Mishimoto Catch Can
-Mishimoto Aluminum Radiator/Silicone Hoses
-Spal 12in Fans
-160°F Thermostat
-Prothane Motor Mounts
- Mods-EMS & Logging
- -Ecmlink V3
-93 Octane
-Clutch Switch Delete
- Mods-Drivetrain
- -ACT 2600 Clutch/Pressure Plate
-Fidanza Lightweight Flywheel
-Stock 5 Speed Transaxle
-DSS Aluminum Driveshaft
-LSD Rear Differential
- Mods-Handling
- -Tokico Struts
-Eibach 1.5in Lowering Springs
-07 Outlander Calipers/Rotors
-1G Rear Calipers/Rotors
-Hawk Brake Pads
-Evo X Wheels
- Parts Wishlist
- Fully Built Motor and Trans
