dillon paros's Talon TSi
- Year
- 1996
- Model/Trim
- Eagle Talon TSi
- Mods-Bolt-on
- drilled an slotted rotors
16 g turbo (set at 15 psi)
greddy blow off valve
Recirculation kit
3 in greddy hard piping to i.c.
full 3 in exhaust from headers back without cat
manual boost controller
flattop pistons .20 over bore
3 angle valve job
A e m wide band
boost gauge
17 in wheels
Projection headlights
Smoked out taillights
Pacesetter header
.ACT stage 3 clutch
750c.c. injectors
Fidanza 5.lb flywheel
Poly motor mounts
Launch control
Tuned e prom ecu
Shepard race trans
pace setter haders
- Mods-Engine
Recirculation kit
3in greddy hard piping to i.c.
6.full 3in exhaust from headers back without cat
3 angle valve job
A e m wide band
boost gauge
17 in wheels with 70% treat on tires
Pacesetter header
ACT stage 3 clutch
750cc injectors
Fidanza 5lb flywheel Poly motor mounts
Fresh tune up and oil change 3-1-1313
New belts
Launch control
Tuned E prom ecu
Shepard race trans
pace setter headers
- Mods-EMS & Logging
- tuned E prom ecu boost battery oil pres. turbo timer launch control
- Mods-Drivetrain
- fwd
- Mods-Handling
- drilled slotted rotors 17 front 18 rear Enkei racing rims
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
