(JayBird) 94 Talon Tsi
- Ownership Status
- Currently Own
- Year
- 1994
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 14b
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 3in Buschur Racing Turboback exhaust.
255 Fuel Pump, FPR and hardware to the fuel rail 660 injectors . (not installed)
- Mods-Engine
- aftermarket cams not sure what type, bottom end
- Mods-EMS & Logging
- boost gauge, A/F gauge
- Mods-Drivetrain
- None
- Mods-Handling
- None
- Parts Wishlist
- Eprom ECU w/LinkV3
Coilovers: Feal or similar
Suspension: Looking into a tubular subframe or working with what's there.
Turbo and Manifold: 6266 or something similar.
Front mount and supporting hardware for the above Turbo:
Coolant and catch systems:
Drivetrain:
-Driveshaft:
-Transfer case:
-Rear Differential:
- CV Shafts:
Brakes: CTS swap?
Ignition:
Fuel System:
Methanol injection:
Wheels and Tires: Basset or American Racing AR23 Wheels and M &H Muscle Car Drag DOT Tires.
- Background
- Goal Restore/Refresh: Hardware, Drivetrain, Suspension, Motor, Engine Bay, Big Turbo and supporting mods to HP Goal of 5-650awhp. While being able to run out to town and back occasionally and 45min to the Drag Strip.
I acquired the car in high school and have held on to it with plans to restore it to street use. its ran off and on over the past 12 years but i never went though it and made it reliable. I have started the process of identifying all the components that need to be replaced, currently rebuilding the shifter and misc bushings along with removing the fuel tank and replacing the fuel pump and lines. I plan to pull the rear sub frame assembly and take care of the rust and bushings along with addressing anything that is bent.
