my daily the panda
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- full 3in turbo back, ported 2g manifold, big front mount intercooler, 2.5in piping ,ebay bov, cop conversion, nsx boost controller, ebay radiator, blue silicone hose kit. shaved valve cover. (not a bolt on) teenage mutant ninja turtles head liner.
- Mods-Engine
- HKS 272 cams, stage 3 head, arp head studs evo8 560cc injectors MHI real 16g turbo@ 20psi with port and polish, eagle rods and je pistons. wally 255lph fuel pump, aem afpr, gates racing blue timing belt, ACT streetlite flywheel.
- Mods-EMS & Logging
- custom flashed uprom ecu, gm mass with translator. AEM wideband with glowshift gauges , 30psi boost gauge, water temp, volts, exhaust temp.
- Mods-Drivetrain
- Shep stage 2, 4 bolt rear end ACT 2600 with street disk,Ingalls Smart Arm Camber Kit, b@m short throw shifter, skate board bearings for shift linkage.
- Mods-Handling
- Tein springs 1.5in drop with adjustable kyb's 17.8 white drags. 2g duel piston calipers with slotted rotors .
- Parts Wishlist
- carbon fiber hood, new paint job, aem adjustable true time cam gears, solid shifter bushings, clear timing belt cover. ecmlink v3. just want to keep it reliable but I may go back to a 20g and upgrade to fic 1000cc injectors.
- Background
- This is my 4th dsm and my daily driver, it was built by a good friend of mine and when I seen it I knew I had to have this one since the early 1g panda were alway my favorite. Ran 14.00 Flat on 10psi last summer can't wait to see what she will pull off on 20psi this year.
- 1/4 Mile E/T
- 14.00
- 1/4 Mile MPH
- 106
