Raymos24
- 257
- 0
- Jan 22, 2007
Boston,
Massachusetts
I am having an issue with my clutch fork being too far over to the driver's side. I did the clutch about 1.5 years ago and it was never really ran WOT because of lack of tuning. Finally, I was able to do some WOT tuning and my clutch is slipping at full boost. I do not remember if we added any washers to the pivot ball but it sure does look like I did. What are the consequences of running the car with a clutch like this? The car has no engagement issues and goes into every gear fine. Here are some pictures of my situation:
The second picture is with the clutch pedal depressed. So can this be causing my slipping clutch? I have adjusted the clutch from under the dash and no matter how far up or down I engage the slave reacts the same way. Is there a way to fix this issue without dropping the transmission?
