Please Support STM Tuned
Final checklist help
TurboLaserRS
512
6
May 14, 2011
Dayton, Ohio
Hey guys. I just wanted to run this part list by everyone real quick and make sure I got everything necessary to get my head reinstalled and do the timing and stuff.
Brand/Product / Part #
Gates powergrip timing kit -TCK167
OEM Hydraulic Tensioner -MD164533
Fel-Pro Head Bolts -ES71175
Fel-Pro Upper engine gasket set-
Fel-Pro Turbocharger gasket -ES72787
Gates 195 degree t-stat- 33489S
Gates T-stat gasket - 33644
Haynes Repair Manual(free)
Airtex Water Pump- WP860
NGK Copper Plug x 4 BPR6ES
Beck Arnley fuel filter - 0430918
Is there anything I need that isn't on this list that I am forgetting? Car has 140k on it. I forgot to mention that the entire front side of the engine (timing side) is very dirty. Even the old water pump is covered in stuff, so I'm thinking the old head gasket blew. I have read a couple places to replace oil pump seals but that sounds even more complicated and I'm not sure if its completely necessary. In the 8 months it has sat, I haven't seen one drop of oil under it.
Let me know, I'm ready to order today.
To be sure, oil pump, all gaskets, front case gasket, oil filter housing gasket, anything you havent done since your there.
Holy crap! I just looked up an oil pump, that would put me about 200 dollars over budget. I'm gonna just see if I can replace the seals then.
By front case are you talking about a crank seal or the timing cover gaskets?
I think I found my leak. When I removed my cam gears off my bad head I noticed there was a ton of oil that ran down the side of the head and probably on the water pump there. The question is, how many seals so I need? 2 or 4?
