wahl
- 0
- Sep 14, 2010
Brandon,
Wisconsin
I recently purchased some fic 1650 high z's and installed them. I used fic data sheet values provided and its super lean. I've searched and found people have had really good results with the numbers provided so I'm a little stumped. The car is 6 bolt swapped on Ecmlink V3 with sd. All the simple checks have been made like BLT and base timing checked. Base fuel pressure was also set after install. I've read to add deadtime in the DA values, but also read not to touch them. Im just looking for help at this point because I'm becoming a little irritated. Ill see if I can post a log in which i might have been playing with global to see if it helped. Thanks!
