a91eagletalon
Supporting Member
- 278
- 13
- Aug 24, 2005
Norfolk,
Nebraska
Ok guys I don't have any test done yet for no start but this I real odd I recently reinstalled the motor AGAIN we got everything back in minus the cooling stuff I just wanted to see if it would run . and I started up good and idled for about 15 sec then I shut it off then started it again and let it idle everything seamed to be great but them I gave it some gas up to like 3000 rpm or so once and then it just went dead on the spot so I tried to start it again and it will crank but there is no sign any more of it even wanting to try and start.
I will do some tests Monday after work but I thought I would put this out there to see if this has happened to any one else or if someone had an idea what caused it.
Thanks guys
Thanks guys
