4g64 DOHC build question
Clever Gs-t
53
Oct 12, 2011
Clever, Missouri
I have read up on the 4g64 DOHC build. My question is about the timing belt. I want to run a performance belt from HKS. But they do not offer one for the 4g64 so I am told. They do offer one for the 4g63 though. I know the 4g63 belt is 153 teeth and the 4g64 is 154 teeth. Is there a way to modify something on the tensioner to make this happen?
Thanks in advance
You can use double tensioner pulleys.
For example:
Wow that's cool didn't know about the double tensioner pulleys. :thumb:
What are the other options you know?
My opinion is, that stock 4G64 timing belt can handle up to 300-350 Hp easily.
If you are worried about breaking it, then just replace it sooner than after 54K miles. It is cheaper.
That`s what I do, have always done and keep doing. :thumb:
On the picture have G64B, with 4g63 dohc head and 6-bolt 4g63 oilpump front end.
You can see the head gasket`s height from water pump, which is 6mm (1/4")
Both tensioners are exactly the same. Use 4g63`s timing belt kit.
BUT, there is a catch- timing belt cover does not fit as the best as it should be. Why?
1. Deck height
2. Right tensioner is about 5mm to the right- may get rubbing to the belt cover.
Ofcourse you can heat the cover with hairdryer and bend it a little bit and cover the missing 6mm on top with duck tape or etc.
