Please Support STM Tuned
1G 14b Fire Ring (round metal seal thingy)
Mokkan
73
7
May 10, 2013
Hampton, Georgia
The fire ring (the circular metal seal between the turbine inlet and exhaust manifold) turned itself vertical while I was installing the manifold and I did not notice. After running for a few thousand miles, it is now melted, misshapen and useless. At least it didn't manage to get down to the turbine blades. Anyway, how necessary is this ring on a stock 14b? I have an FP manifold and am running 14psi of boost on an unmodified 14b.
ya, its just a guide for the turbo to align with the header. you can port the turbo hot side to remove the seat for the guide. itll be better exhaust flow
If you're running a manifold that doesn't have the groove to hold the ring in place, you don't install the ring.
Despite what others have stated, it's actually there to keep from burning the gasket over long-term use and has nothing to do with alignment. I've actually seen turbos that had loose manifold-to-housing bolts yet they didn't leak at the joint thanks to the sealing ring being intact.
Thank god it didn't get down into the turbine- I've seen this happen on two 14B's, junking both turbos.
I initially thought it was for alignment, but that thing is too loose and obnoxious to install to have been intended as an alignment aide. Gasket protection would fit with the 'fire ring' name a little better. The FP manifold is nearly impossible to torque properly, so it would be nice to have that thing in there if its intended to help with sealing. I guess I'll leave it out until I manage to find a properly sized one. Is the 14b the 7cm ring?
It would be nice to port the inlet, but I use this car for SCCA Rallycross and the class I'm in does not allow any modifications to the turbo.
