Hello, well I will be beginning my "mini tear down" soon with removing the head for new gasket, and arp headstuds. As well as putting in my new South Bend Clutch TZ/B-Series Kevlar/Ceramic and Act lighten flywheel. So with that in mind, I have decided to post pictures of what I am doing and how it is coming along once I get started. I like input from people and I like advice. As the title says this will be my Daily Driver and I am shooting for 350-400hp. I would really like to see the 400hp. I will list what I have and then what I think I need/want. If you feel I need something or don't need something let me know
Oh and yes I did/do my maintenance I don't wanna blow up my engine 1st pull
. Also I just read the new thread on maintenance and I feel better knowing I did all that was recommended
I will of course look over other parts while I am in the engine and probably ask questions once i'm there too.
So current list of mods:
1. DSM Link v3lite
2. EVO3 16g bought from Forced Performance. with install kit
3. Greddy Type-S BOV recirculated
4. 3" Turbo Back Exhaust
5. Ebay Intake
6. Aeromotive Stealth 340lph Fuel Pump / drilled Siphon to 1/8" - with rewire kit
7. Hallman Pro MBC
8. FIC 1150cc fuel injectors
9. Aeromotive A1000 AFPR
10. PR FMIC
11. NGK Plugs/Wires
12. AEM Wideband Uego
13. AEM Boost Gauge
14. AEM Oil Pressure Gauge 0-150
15. South Bend Clutch Heavy Duty TZ/B-Series Kevlar/Ceramic Clutch Assembly
16. ACT StreetLite Flywheel
17. OEM Throw out bearing
18.Drilled and Slotted Rotors
19. FP exhaust manifold
20. Fluidampr
21. 18" Rims -235/40r18 Need a good set of street tires / dry &wet -still looking
22. PUNISHMENT RACING TIAL 38mm MVS WASTEGATE + RECIRCULATED O2 HOUSING
23. Fuel Lab fuel filter
24. Koni Yellow's with GC kit
25. Short SS Clutch line
Stuff I may need to reach 400hp?
1. 272 Cams - IDK what brand or if even needed
2. Adjustable cam gears? again IDK if needed
3. Water/Meth Injection? - This item looks really awesome to me. I like that it reduces heat but I am not 100% sure how it is used especially for a DD. At first I thought it was similar to Nitrous but now I don't think its like that. Seems to run off of a certain boost psi? Which would be great because that means it would not always be being injected until a certain psi and it is automatic meaning I don't have to have some button to press while driving?
Well I also thought I would list some fun stuff for the car too that aren't performance related
1. Symborski shift kit
2. B&M Short shift
3. Skateboard bearing shifter mod
4. Pioneer 6300UB Deck, Rockford front and rear speakers
5. RTM Racing Shift Knob -Mitsubishi Logo
6. Gates Blue Belts
7. Powder coated Metalic Blue Valve cover - done by 19TSI95AWD
8. Aerocatch locking hood pins
These pictures are old but I thought I would upload now and then you can see it during my install of most of the mods I listed and then the finished product.
