- Thread starter
- #26
SpecialtyAuto
- 54
- Nov 27, 2010
Green Bay,
Wisconsin
The crank was undercut .010" when I took it to the machine shop (rod bearings) . At that power level is the strength of the crank a concern?
Also the pictures you have in the first post have cop setup. When I had the car I was thinking about getting an dynatek arc 2 since alot of DSMLink guys were running those.
Did you break in the clutch at all?
Is Luke doing the tuning?
Luke does all the tuning for Beyond Redline, so yes. Clutch was broken, from Luke actually, got it from his old 92 red talon. The coil on plug set up in that picture is what was giving us problems, so i put back in the stock wires and coils and it pulled strong til 35lbs, then broke up over that when we tried to run 40. So I need the COP working correctly, beyond redline tried re-wiring it, but its still breaking up even under like 4lbs of boost. Its just not working correctly, something is odd. But for the time being, I'm running the stock coils until it's figured out.
