danl
- 880
- 263
- Apr 8, 2002
Severn,
Maryland
Results were 420whp/350tq. Boost was 26-27psi tapering to 23-24psi.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I really think it's at least as much the hotside holding back 16G's as it is the compressor.
I'd really like to see some before/after results from getting the hotside CNC'd out to 8cm. I think a 20g would really shine with this done to it.
You can't just machine a housing out to a larger AR. Porting a turbine housing is only for improving flow through the entry area, and not the actual scroll around where the exhaust gas enters the wheel.
If you want an 8cm housing, just buy an 8cm housing.
Thanks Danl for posting your results...this is exactly what I wanted to hear
