WTF do these plug into?
Empyrials
152
Jun 12, 2003
Wichita (Aka, Hell), Kansas
ok really i've done a lot of searching and come up with nothing for these 2. I bought the car like this and i only owned a 2g before this so ya...
every other plug is accounted for but these 2, no idea. And i'll assume i got the CAS pluged into the right plug because the car started LOL. This is a 90 GSX with a whole bunch of stuff eliminated so i'd assume these aren't even needed but i'd really like to know what they are. Manuals don't help at all
The plug on top here is off the firewall(CAS?), the other is off the battery pos side(no idea)
beats the shit out of me bro i dont even think i have those plugs!!! LOL let me go check my car man hang on....
well i could not find them.....weird....none of my plugs have that color on them.... i know for sure that none of those plugs hook up to the CAS....that is for dam sure.
as for the lower one.... do you have ABS in your car? if you do...check on the right side of the ABS module when you are facing the windshield...there is a plug that goes there.... ( Not attached to the ABS module ) its a box on the right side of it.
thats the best i can do for you...my car is all apart so its kinda hard for me to know exactly....i cant keep posting since i dont really know and its against policy to reply like this. but i know none of those is CAS
wow at least i'm not the only one LOL
Pic 2 might be coolant temp? I haven't messed with the 90 model very much.
Oliver
[email protected]
i wish i was at home to double check that it's right, but i already have something plugged into my coolant temp sensor
as for the top plug it's gotta be CAS because the car fired up right? that's what i have the CAS plugged into.. the 2nd plug in the top pic i've no idea.
No ABS.
i wish i had a local friend who had a 90 :/
I'm pretty sure the bottom pic goes to your Throttle Stop Switch on the backside of the throttle body.
+ 1 for truth.
Just pulled my TB and that was definately attached, check the of the TB facing the Firewall near the return spring.
Also, for those plugs in pic, right above your fuel filter, maybe a couple inches towards the driver there is a number of female plugs which fit the ones you have loose, though sadly I can't tell which goes where.
+ 1 for truth.
Kick ass thanks! i'll delete that pic as we know where it goes now
Forget that last post
There are 3 plugs on the firewall that go to the throttle body area.
I think they are
CAS
ISC
The 2nd pic is for the Idle position switch
so is the top plug there(firewall side) the CAS plug? or is it the bottom one, which comes down from the where the positive terminal is. and still not sure what the other one is.
Someone mentioned cruise control, that was removed before i got to the car so i guess the plug on the firewall would make since, but that's the plug i think the CAS plugs into LOL... ###...
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
