which install kit?
I have used the one from FP that I got through MAPerformance and I loved it. Very easy to install and came with exactly everything I needed.
Just make sure whichever kit you get it has a J-pipe for a FMIC. I got my install kit from dsmparts.com and the J-pipe was for a SMIC. Made it a bit difficult to get past the front motor mount. I then switched to a J-pipe from Punishment Racing that was made for a FMIC and piping was much easier to deal with.
Using an oil feed from the head is a bad idea, the head does not supply enough pressure (it varies to much). Going straight off of the oil housing is your best bet. People do run from the head, and have good luck, it's just not the optimum placement.
To the OP any kit will essentially give what you need to install it, remember cheaper is not always better.
  • Wanted 6 bolt NT water pipe
    • chrisman287
