2G Which 1G CAS on 2G ECU
ok_opie
Jan 6, 2006
KC, Missouri
Ok I have done the 6 bolt swap with 1 major prob yet. I keep tracing it back to either CAS or ECU. I used the CAS off the 94 GST the engine came out of and wired it up as stated @ http://www.magnusmotorsports.com . Tomorrow I am wanting to try another CAS any suggestions on what to pull it off of? I read on magnus that the 91-92 has Optical Effect, 93-94 Hall Effect. They state the ones they use are same as 89-90 Galant so now I am leaning towards that maybe my problem.
What is the major problem that you are having? More information is always better.
The resolution on the 91~92 is 'slightly' better, but you shouldn't have any issues with the later CAS as long as it's a known good sensor. (except for the occasional random misfire~ P0300)
I've been using a green lid for over 2 years now without issues..
Well the total list of problems and trials are on this thread .
http://dsmtuners.com/forums/showthread.php?t=224988
I don't want to start multiple threads on the same problem. But in a verry short manor the current thing is injectors 1&2 will shoot fuel 2&3 do not however I got them to 1 time. Then re cranked it on same setup and they wouldn't work. I can not get them to reproduce and work again
Well I pulled one off a 91 N/T it works. I don't know if the 94 I have got broke during shipping or when the crate fell from about 5 foot in the air during unloading
