What will I need to do to keep camber toe alignment and anything else good?
90TurboPOS
41
Mar 13, 2004
San Jose, California
I have some sportlines and AGX's going in... I imagine this will cause some problems so what items will i need to get, or what will I need to do to keep the suspension setup resonably...
I was looking at this to fix the camber?:
http://store.summitracing.com/default.asp?target=partdetail.asp&part=INT-99-9-007&FROM=MG
Is it correct to assume that the rear will be okay.. This is in a 90 FWD laser... It seams the rear suspension probably wont get out of whack.. if so what do I need to correct it?
Also I heard a vicious rumor that the rear has limited travel and there are stops it will hit if I lower it too much.. Havent peaked my head under to check it out..
Any help would be greatly appreciated. I intend to install the shocks/springs tomorrow as well as take it to the shop and get new tires and alignment done....
Thanks in Advance...
You won't need any camber kits with your car. Even with extreme lowering your camber won't change. I'd be suprised if the toe changes, but it might be a good idea to get it checked after you finish the suspension mods.
talonTSIDriver said:
I lowered a 1g AWD with Megan 2inch drop racing springs and the rear camber was REALLY bad. I did a lot of reading in on it and you have to cut the lower part of the control arm and extend it outwards to fix the camber.
http://www.vfaq.com/mods/wayback/arms_mod.htm
Yea, except he's FWD. The 90 Laser only came with FWD, I know cuz I have one, too. When lowered, camber doesn't change. It has a completely different rear suspension than the AWD version.
gg actually having an axle
