What size turbine housing do I need??
Oneslowgs-t
177
7
Jan 16, 2012
Danbury, Connecticut
So I have what I believe is a precision 6162.
The measurements for the
compressor wheel are
(inducer 61mm) and (exducer 82 mm)
Exhaust Turbine measurements
(Inducer 61.75mm) and (exducer 71mm)
Right now I have the dam flange turbine housing and I want a t3 so I can run my tubular manifold.
QUESTION : what millimeter housing would I need for my turbo??
hmmmm have you tried calling extremepsi? Or any other PTE vendor for that matter? And ive never heard of a 6162. a 6262 yes. Part number on it? Pic maybe
6162 is the new numbering for the old 6152. Whatever turbine housing you get would need to fit a T350 turbine spec....best to get this from PTE so you're sure to get the correct thing.
They'll likely ask if you want .63 or .82 a/r as well as what type of outlet flange you want.
