pj91gsx
- 2,717
- 9
- Nov 25, 2007
Stuart,
Virginia
i have a 97 talon, the rear end say 3.545 on it and i thought the gear ratio was different for the 97-99 compared to the 90-96.
All the stock trans, x-fer case, and rear gear ratios can be found here:
Tranny gear ratios for DSMs
Rick - '91 GSX
I'm conused that you're confused!! WTF
That chart lists 1G, 2G, AWD, FWD, VR4s, Manuals, and Automatic.
What else is there??
It was last updated in 2000 so it doesn't include 3Gs or 4Gs, but we're not talking about those... are we?
Rick - '91 GSX
Apparently the shop manuals don't even mention a change in 2g ratios. That's why the DSM community is awesome!! We know more than the factory guys do!!According to the Shop Manual CD, here are the gear ratios .... The Shop Manuals for the different years sometimes conflicted with the Tech Manual (the CD only has the early Tech Manual, so only covers 1Gs), so I put what I thought were the proper numbers in some places
The rear end ratio is the same from 1990-1999 -- the difference is in the gear ratio of the transfer case of 1990-1996 vs. 1997-1999, and the 58-tooth front diff ring gear in 1990-1996 vs. the 57-tooth front diff ring gear in 1997-1999 transmissions.
Thanks. I managed to find the same info here: http://www.4g63turbo.com/tech/eclipse-5speed-swap.htmlOf the transmission? well, I guess the easiest way would be the part number on the bellhousing. W5M33-2-MUZT is the 97-99 AWD transmission if it is unmolested.
