[vid] thunderhill blooper, open passing stress
Constructive criticism:
1st vid: When going through the turn 5 bypass try getting the car one car width from the left. You are too far to the right. When you start going faster you will scrub off speed using the line shown.
2nd vid: You missed the apex to turn 14(the first turn shown in vid). If you watch your vid you will see that there is a flat spot at the end of turn 14. Go inside a little further, hit that and it will set you up nicely for turn 15 and pay off big in speed down the front straight. The same applies for turn 4. There is also a flat spot in the FIA curbing at the end of 4 that will setup a nice line if you are using the Eagle's Nest (turn 5).
Remember it's their job to pass you, not your job to let them pass.
Overall nicely done. More practice will get your times down considerably:thumb:
