turbo xs washer question
spatulahunter1
253
Jan 19, 2004
portland, Oregon
does anyone offhand know how many washers a turbo xs bov should use to run 14-15psi on a t 25?
And before anyone gets into lecture mode the thing is recirculated. My boss welded a pipe onto the end so i could use it. I got the thing for free so why not?
im not sure but the first thing I would have down was call Turbo XS.. and ask them to see what they say... It would be easier...honestly
probably right, i just figured enough people on here have them that someone would know off hand
i called them and they said between 2 and 4 is typical. The washers only keep it from being open and creating a vacuum leak at idle. The 11 psi spring and the manifold pressure keep it closed when under boost.
