TB boost tap.....?
boozeted
59
Mar 10, 2004
cheyenne, Wyoming
There was a VFAQ on it, but the addy is down and has been for past couple of days at least. Anyways, I remember the site saying tie to P, which is either red or green. I have a 90 however, and it's a little different. I just removed my EGR stuff and need to plug 3 of the holes and tap the other for boost gauge. Anyone have a 90 and done this install? Which one was it? From left top being 1, right top being 2, side top one being 3, and bottom side one being 4.
Please, need to get this done tonight.
sorry, BOOST GAUGE TAP. The reason I want it on the TB is b/c it will be more accurate to whats going into the mani. Plus I removed my FPS and wouldn't want something bad to happen to my gauge and also my FPR at the same time and/or vise versa.
Thanks.
anyone? yoohoo...someone has to have a 90 out there with a boost gauge tapped into the TB instead of the FPS.
wheres the tuners that always help mez0r? or am i just talking tomyself. that might be the case too.
Yeah I tried this post also and got the same response you did. I just said F it and put it on the FPR. It worked great and has been for about 2 years. Nothign will happen unless a hose falls off but that will just raise fuel pressure a bit. No biggie.
Michael
:laser: :talon:
ya..i just tapped mine into the FPR also. works great.
Thanks.
http://www.roadraceengineering.com/instructions/vdoboostgaugeinstructions.htm
http://www.dsmtuners.com/forums/showthread.php?t=102883&highlight=boost+gauge+install
http://www.dsmtuners.com/forums/showthread.php?t=81514&highlight=boost+gauge+install
Boom!
Should tell you everything you need to know about installing one.
98RedGs said:
Its not the actuall install that is the problem, it is the port on the TB that is the problem. 90 is the bastard year that is different and it seems that no one knows what port to tap.
Michael
:laser: :talon:
Michael
:laser: :talon:
Dam...
That sucks bro, sorry I thought those would help yah. Because on the RRE one it shows 90-94 but I guess your telling me that the one on RRE applies to 91-94 basically. ;)
:p
  • Wanted 6 bolt NT water pipe
    • chrisman287
