talon eclipse swap back up lights
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
How do you make the eclipse back up lights work all I see is the light has two wires one power one ground the talon has three wires one black one green and one green with a white strip how does this work thanks. Trying to turn my 2g talon into the 1999 eclipse
My best advise is get a light tester that tells u which on is power and which is ground and just put the ground to the ground and power to power. I was thinking of doing my 1ga talon to a 1gb eclipse but i am undecided now because the talon look has grown on me.
put the car in reverse so the reverse lights get signal, use test light as mentined, confirm power, take shifter out of reverse and see the power wire went away. done.
