Strut bars Vrs Tie bars
brassnuts911
49
Mar 17, 2009
Sturgeon Bay, Wisconsin
Im placing anouther order after i go to the bank and i was wondering what would give me the best handling right away? Should i buy tie bars today or strut bars? I was planning on buting megan racing upper strut bars or tenabe underneith for the tie bars.
Thanks.
Strut bars at least on a 2g AWD. The lower tie bars add that last itty bit of steering response and handling improvement, upper front strut bar gets you the most. I run the RRE upper front, upper firewall, lower front tie bar, upper rear strut bar.
What the 2g's are dying for, after you've reinforced the chassis sufficiently, are some polyurethane bushings. This after you've swapped to aftermarket springs, struts, and tires with stiff sidewalls.
