starter free spins
94eclipseboy
Jun 13, 2010
westwego, Louisiana
ive looked at old searches but they close to what im having.
the problem?
i blew my head gasket car was running started up fine took the top of my motor apart changed what had to be changed put everything back together go to fire it up an the starter was jus free spinning tried push starting it still nothing i buy a new starter it had a defect get another one that one was sticking so i got another one this one is good but still free spinning i dont know what it could be cause i didnt mess with anything on the bottom half of the motor for this to be happening oh and it is a 5speed cause i no a/t and m/t have different throws
any help would be great thanks
I bet you $20 you have a FWD starter. If I recall correctly, the awd flywheel is smaller than the fwd flywheel.
its a fwd ima have to make sure i have the right starter but im not understanding how it was working fine before i took my head off to change the head gasket and i put everything back together an go to crank it an the starter is just free spinning its confusing me and probably everyone else to
I was under the impression it was an awd because its a gsx.
how i check the flywheel turn it with my hand right
yeah sorry bout that LOL i put gsx cause im depating if i want to awd it
the thing about it tho is the starter that was in the car working did it to so i dont think its the starter being for an automatic but it crossed my mind to thanks for the thought tho
Did you by any chance remove the ground wire to one of the starter mounting bolts? Could have a poor ground....enough to spin the starter, but not enough to make the bendix engage?
i no i loosened a ground that was to the block but i couldve swore i tighned it back but ima double check everything ima try an work on my car today an left everyone know what happens
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
