Spare tire
n0c7
568
5
Jul 2, 2004
Edmonton,
When I bought my 95 Eclipse GS-T the hatch was gutted and had no spare tire. I've been told that the 2g's have a full size spare, but I don't know the size of the rim and the size of the tire. Also, what is the maximum size(rim and/or tire wise) that I can fit into the hatch and have it bolt down properly? Reason I ask about max size is that my ride is dropped 2 inches and I have a low kit with 18" rims and 225/40/18's.
my 2nd gen has a space saver and the stock size for the GSX is 215/55/16 i think FWD is 205/50/16 i belive i'm not positive on that
Ok, so is a space saver tire proprietary to the manufacturer or can I find one of these at a local tire store?
Defiant said:
You were told wrong. Keep in mind that a good 90% of what you'll be told about DSMs is wrong.
Check your local junkers for a space saver, or try a classifieds ad on here.
:D Pretty bad when its the local Mitsubishi dealership feeding you the wrong info hey?
Well I found a guy local who gutted out his 99 GSX and I picked up his spare. He told me that the GSX spare is slightly larger, anyone know if the area where it sits is the same size in all 95-99's?
The 95's must have a smaller storage area than the 97-99's because I can't get it to sit flush nor mount down, can anyone confirm?
I'll buy the fact that the GSX spare is bigger. Since the diameter must be close to the normal wheel. I don't know why they wouldn't just do that across the board though.
Can you tell me the tire size? I'll check it against mine.
Defiant said:
Did you try flipping it over?
Yep, and tried to adjust it in every way I could and it wouldnt drop in :confused: Maybe I'm missing a part in there? In Layers it would be:
Carpet
Board
Wingnut clamp holder
Spare Tire
Metal bracket
Windshield Washer Tank
Frame
Yes I will get back to you on it tonight when I get home.
