Solid motor mounts help
MadrussianSVT
95
Jun 9, 2011
Minneapolis, Minnesota
Found out that 3 out of 4 motor mounts are shot, so I ordered some prothane solid inserts. Is there step by step DIY on the whole process?
The other two, front and rear are just inserts. They sandwich the old rubber mounts; it's that simple!
The front is just an insert, not a whole mount. You have to have a good mount to start with. If you need a new mount, I just bought one from Rock Auto for under $20...not the nicest mount, but paired with the inserts it's doing great for me!
well I thought that the side two were inserts as well. So what is the difference in between side prothane inserts and front insert?
The front and rear mount prothanes basically are inserts that "sandwhich" the stock rubber mounts and provide substantial additional rigidity. As someone says you need to have existing mounts that are in decent shape or they will have little effect. The two side mounts fully replace the stock rubber inside the mount housings and require the original rubber to be removed - using the cut/burn technique.
The front mount is easy to do and even the rear to a lesser degree.
For each front and rear (doing them one at a time) remove the bolts and mounts, put in the prothane inserts on either side and bolt back up.
For the rear one first remove the battery and battery tray for easier access and also jack up the car (put safety jacks under to stay safe) so you can access one of the bolts and nuts from below.
I kind of took a quick look at the rear mount when my car was on the lift and I cant even see the mount from there, any tips or reference pictures on those bolts you were talking about and how did you got them out?
  • Wanted 6 bolt NT water pipe
    • chrisman287
