SO, i install stage 3 suspension on my mr and it turns like crap HELP
Status
Not open for further replies.
DeviantClipse
418
May 18, 2003
New york city, New York
like you read it tunred better on stock. mine is not tuned at all. how do you know how to tune and if anyone has this setup what are you running on the full customizable suspension on the mr.
i have
racing chip
stage 2 turbo
racing exhaust
stage 1 weight reduction
racing brakes
help me make this thign handle
phil
( i figure we all need some help on that tuning part )
First off tune your suspension...
and then get the ayc it handles like a dream with everything but the power mods done... then I put it up to 390 hp and it is fastin the straight and even faster in the turns.... you don't need turbo upgrades... you just need to keep speed in the corners....
He asked HOW to tune it. I need help too OMG
ok... Stiffen up the suspension alot... a little more stiff in the front then in the back... like
for shocks (i think 15 is the highest)
13 in front
11 in back
for sway bars
rear sway bar full strength front leave stock (or about 2 less stiff)
*edit* oh yeah lower the car to 100mm front and rear
everything else in the suspension tweaking make it 1 -2 points stiffer.
I use the s2 tires... they are good enough and last pretty well for longer races...
and get the first 2 stages of the lightweight, that will help alot... I will take a screen shot of my setup and post a pic for you after work.
Here's my setup and it turns like a dream.
Spring rate: 10 front 12 rear
Ride Heigth: 122mm 122mm
Shock setting: 4 front 8 rear
Swaybar setting: 2 front 6 rear
Brake bias: 8 front 10 rear
You should love the way it handles set like that. :thumb: :dsm:
Status
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
