sheptrans
rock1t
905
6
Jun 30, 2008
Bowling Green, Kentucky
Alright, found a good deal i think. Going from bowling green, kentucky to toledo, ohio, in about 8 hours after i sleep.
Swapping my stock 91 tsi trans for a shephards transmission stage 4 and paying 1500 for it.. it has about 5000 miles on it and been to the track twice... the guy is upgrading to a dog box...
what you all think ?
Sounds good if you ask me, doesn't the stage 4 setup run about 2k? What was the guys time on the track?
around christmas time i to will be buying a shepard transmission. what type of fluid would recomend as "good fluid" for this type of tranny?
If it came from shep and is still in good condition it should be good!
just my $.02
turbo
yea ### i tried the royal purple synchromesh and it dosent seem to be doing to well in my stock tranny and a lot of people on here told me that using royal purple is a bad idea and it dosent perfom well at all. is pennzoil the second best then next to redline mt-90 for dsm's?
There are a lot of threads on what gear oil to use so have fun looking at the different types. If using a shep tranny call them up an ask what to use.
TRE tansmissions recommend redline, and jacks trannys recommend Mitsubishi MR 6-speed oil or Redline Heavyweight Shockproof 50/50 mixed with Valvoline 80W-90.
I wouldnt recommend running just MT90 in a transmission as its too thin. Use the factory fliud or try pennzoil and redline shockproof mix.
