Running more boost without fpr?
SpoolN
386
Jan 20, 2003
Coventry, Rhode Island
I just got the sbr fmic, and fuel kit with 650's, also a wideband. Would running around 20-22 psi be ok without a fpr or should I wait and snag one before I start running that amount of boost. I have the evo 3 turbo.
It isn't exactly a must because stock you have 43psi of fuel pressure which is a pretty good amount. I would get one soon but it isn't a must yet. You can run that kind of boost without one but I would monitor your car and keep an eye on it.
Thanks for the help, Yea I will have a wideband and using my friends datalogger
Maybe you didn't hear me the first time, there are no fpr overrun during WOT. In other words, an AFPR is cruicial for the 255 but it has no impact on how much boost you can run.
Am I getting this right fpr overrun cause irratic fuel pressure at idle and partial throttle, confused on the actuall meaning. So your saying yes get a afpr soon. correct
He is right. I was assuming you had a 255. Should have read your profile first. You don't need a AFPR until you upgrade your pump. Which I suggest you do as one of your next mods in the near future. Or at least rewire yours for now.
So I should get a fpr is this one ok, and will it come with everything i need for install? Fuel Injector Clinic Aeromotive AFPR and Install Kit
Correct.
Your original question was what I was refering to on my previous post.
jeffb006 said:
I am guessing that there is no way to sort of tune out these stumbles under idle/part throttle with an afc, correct?
Correct, afc is rpm based and the degree of fpr overrun changes are load based, rpm is only one of many factors that determines load.
