Recommendations for what to get next
g0tEclipseD
292
Oct 29, 2003
San Diego, California
This is what I have covered so far.
-K&N
-o2 elim turbo back
-boost and egt gauge
-MBC
-Symborski Kit
-OEM Heavy leather shift knob
-RRE Resonator Pipe
-type s
-safc
I have about 700 left so Im trying to decide what to get with it...
-X clutch and fidanza?
-FMIC?
-660's and 2g mas?
-suspension?
what are your suggestions
IMO, I would go with either suspension or with the clutch/flywheel setup. 660's are way over kill for a stock turbo, plus I think a FMIC is too. I think you should do fuel, turbo, and FMIC at once, or at least, as close as you can. Just imo!
it depends ... if you will eventually upgrade to a bigger turbo then i would 1st get a ACT 2600 clutch and walbro 225 pump, i didnt see that on your mods list and you will eventually need it. then a gm maft, 2g or better exhaust manifold, turbo (which ever you decide to go with) at stock boost level until you get injectors, and fmic. but like i said i would get a clutch and high flow pump first.
forgot to add to that list above that i have a vr4 fuel pump. I will eventually be getting a 50 trim
