rear disc swap
badbash27
Nov 2, 2008
waukesha, Wisconsin
I have a 99 eclipse spyder and am looking into swapping out the ugly rear drum's for a disc set up. Does anyone know if callipers off of a 95 AWD eclipse will fit? I think they will, but want to make sure. Thanks all
They will but if they're the vented type disc, you might encounter some hassle when trying to buy discs for it. They're on the rarer side so I would use them just for that aspect though. You know everything you need for the swap, correct?
yea, I know of all the parts, I just need to know what callipers will work for the back. I want to keep the two G set up, where they still use the shoes for the E brake cable, and the callipers for the Disc.
All the 2g rear's used the drum-in-disc setup so you don't have to worry. It's the 3kgts that were different.
