Heavy-D
- 86
- 4
- Aug 7, 2004
New Haven,
Connecticut
I probably should have asked this before I tried it. I was attempting to remove the rear bumber on my 1992 eclipse to get at the rust behind and underneath it, then re-attach my bumber. I finally came to a point where I couldn't find where the screws were that needed to be taken out next. My current number of screws is :5 under the bumber, 2 plastic screws in each fender well, 1 metal screw in each fender well, 1 behind each red light behind the rear tires. Where are the other screws? Also, I was thinking that once you take the bumber off, it is ripped from taking it off and is no good. So can I safley take off the rear bumber and if so, where are the rest of the points it is attached to?
