Quick tdc question
Did you remove the cams?? If so, I have never done that so I couldn't give you correct information. I have, however, done plenty of 4g63 timing belts and the first time I did it, I followed the VFAQ. Step by step and very detailed instructions.
Did some reading. I should be able to line up the cams, align the crank marks and torque the cams down and install the belt. Am I wrong?
Correct! The engine should be at TDC on the right stroke if every mark lines up.
