question about crankshaft pulley
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
hey guys,umm i got a really important question the question is::
Does my crankshaft pulley suposed to move??cause my belts broke :( and i dunno why?? so im thinking cause of moving crankshaft pulley but not sure :sosad:
Did you try searching for either of you last two questions?
You'll find a ton of threads on how a bad ECT or broken wires to the ECT caused the car not to start.
Have you gone and looked at it since Keith was kind enough to show you where it is?
Steve
yeaah i checked the sensor ,but everything seems to be ok the wires are good the connector itself still good ,i didn't mesure the voltage,but i will as soon as the rain stops :)
ok i took out crank balancer and the lower timing cover,and i checked the marks and the crank sprocket was 5 teeth's off the timing :(( ,but the thing is i found little peaces of plastic timing cover and a peace of old belt between the crank sprocket teeths.but when i changed my belts and crankshaft balancer i tryed to start my car,and i did like 5-6 times,is it possible that i bent the valves??? cause right now i don't have anything to check compression with
ok so if i bent the valves :( what kind of valves you guys suggest me to go with,i mean which way is better to go : stock valves or oversized valves??? if ill go oversized what should i have to do???? running with oversized valves
oversized requires machine work .
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
