Prothane 13-501 Red Right Upper Transmission Mount Insert Kit
tim3kgt
34
Feb 5, 2003
LiberalProgrsv, Arizona
This kit is meant for the 5 spd but it fits in an auto mount too. the difference is the metal inner sleeve must be removed from the auto trans mount. remove all the rubber then pound out the sleeve that the rubber was bonded to. Just did mine yesterday. fit is just tight enough to need a mallet to get the rubber halves of the new mount into the housing.
good price on this kit:
Amazon.com: Prothane 13-501 Red Right Upper Transmission Mount Insert Kit: Automotive
Thanks again for searching, this is what I had been looking for in my spare time but, all I could find was the entire poly mount kits which I don't need. I've done this once before and saves allot of money. I appreciate you posting back! Thank You for your time!
Figured this was the best place to ask, has anyone had issues when installing the 13-501 in a auto trans mount where the center pin is 8mm too short.
