problems tuning low setting
G9S1X
148
Mar 19, 2004
Fort Lauderdale, Florida
i hopped up from 390cc(auto) to 550cc injectors, for low settings i started with -15 across the board. i know this is rich as hell because u can watch raw fuel being dumped from my exhuast and it bucks at 18psi (not like fuel cut, like when you vent your bov bucking). now that we all know its rich, why does my o2 trim read 120% - 140% at -15 across? and the low fuel trim never moves, sits at 107% no matter what i set the low setting to. i also have a 255walbro low pressure pump on stock fpr. thanks :dsm:
i knew you needed an afpr if u got the high pressure walbro but everyone said you shouldnt need one for a low pressur one :confused:
this may sound dumb, but have you checked your plugs yet? they need to be regapped. 18 psi will easily blow out your spark plugs. when they blow out it feels like your car just all the sudden died. hard jerking and sputtering for a second. then it runs fine once the boost goes back down. very not fun feeling.
chris
  • Wanted 6 bolt NT water pipe
    • chrisman287
