CBT8503
- 53
- 0
- May 25, 2004
Meridian,
Mississippi
I just got threw installing my greddy type RS BOV. Before I installed it i was getting to 15 PSI, and immediately afterward the install I took the car out to make an easy 3rd gear run to find out how the new BOV was working. Boost went past the regular 15 PSI and on up to 23 PSI before I let off the gas. I stopped off at the next place possible and made sure the MBC was adjusted all the way out. I ran again and the same thing happened. Where could the problem lie? Do i need to soften up the BOV? And if so, how would i know i was at the right point of adjustment? There was also a clearance problem with the hood and the top of the BOV that i had to rig up a simple fix. Thanks in advance for the help.
Getting my TLA's mixed up.
