Power Seat wiring diagram
spooled_u_1st
332
17
Aug 27, 2006
Pittsburgh, Pennsylvania
Does anyone have the wiring diagram for the power driver seat?
Mine stopped working a while ago and I never needed to move it until now. The problem is that it is all the way back and lower in the back.
I have the front 2 nuts removed and 1 rear bolt removed. The 1 by the console in the rear is impossible to take out. I can't even get a wrench on it. The top track is covering it.
My only thought is to try to splice in to the front-rear slide motor or the rear height motor. Or is there a way to disconnect them from the seat drive system so the seat will move?
There are 2 gear drives on the front of the seat, one on the left rail and one on the right rail. Remove them both with an allen key. The seat is really hard to move but it will slide.
Hope this helps anyone who runs into the same problem.
